Zoom with Mouse Wheel?
Hey guys,
I’ve read through some previous posts about my question but none seemed to answer it exactly. Either that or I just overlooked the obvious answer. : )
I’m starting to use a new mouse with Maya, and this mouse has a wheel. It would be GREAT if the movement of the wheel (back and forth) controlled zoom in the viewpanels.
I think Max does this by default, but Maya does not respond to the back and forth movement.
Is there anyway to get this functionality within Maya?
Thanks fellas.
hmmm… strangely… I find that maya’s default mouse zoom is MUCH easier to use than max’s wheel zoom becoz you have much more control over the precision of your zooming. you shud just get a standard 3 button mouse without the wheel and it’ll make your life easier in maya…
Well, I’m actually coming off from using a GREAT Logitech 3 button mouse (the Wingman mouse) and it worked like a charm.
This new corldess optical Logitech mouse does a great job also, and it’s great for general use. Having said that, it gets bothersome to physcially push the wheel button in, but if it must be done then it must be done.
In the future I will create a second system dedicated to 3D work, and I will put the Wingman to use on that one.
Thanks for your reply. : )
yeah… I used to own that cordless optical mouse.. however, I found its movement jerky.. you’ll know what I mean if you try to draw circles using that mouse in photoshop and then try it with a normal mouse… the circle drawn with a normal mouse looks much rounder..
why not use both??
i use one logitech regular 3 button(noWheel)PS2) for apps, and one Microsoft cordless Optical explorer USB for surfing and other things.. works great ! !
Although there is extensive keymapping and control customization in Maya, I don’t beleieve the code or any attribs. for mouse input is exposed in Maya.
-I agree with the statements above - I seem to have more accurate (faster)control over zooming using Maya’s scheme, but then again, I’m a total novice in MAX.
kiwi
