Zooxferanim Help
I need help on how to best use zooxferanim script. I have looked at the help that came with the script but I still seem to be getting lost. What I am trying to do is move an animation run cycle (static - not moving off master controller) to a scene where the character is moving. I would like to move the character along but at the same time not moving the master controller. While reading the help it said you can do this ... just I am confused on how to do it.
Just to make this more complex I have animation before the run starts and the master controller is pointing in the other direction. I need to find a way of spinning the cycle around about 180 degrees from the master controller.
these two movies below might explain what I am trying to do. One is the run cycle while the other is the scene.
http://thenutworks.com/playblast/runOtto.mov
http://thenutworks.com/playblast/scene3Help.mov
p.s. I really need to work on that camera ... that is a later job
There is a zooToolBox forum here.
It's been pretty active lately.
