Just posted this at zbrush central:
1http://206.145.80.239/zbc/showthread.php?t=221761
An alternate quicker method for MR displacements.
cheers,
-sunit
created
Nov '04
last reply
Jan '05
- 15
- 3.4k
- 1
user
- 1
link
cheers,
-sunit
Just one question? Why on earth woudl people want thiskind of tutorials... I mean what so hard in setting up displacement using maya and mentalray? You do it like you would for every other maya shader.
By the way you could have gotten the polysmooth for free inside mentalray! Wihout needing to clutter the viewports.
As far as I can see, this method gives a much faster displacement than using the approximation editors for a decent result.
Setting this up isn't terribly difficult, but for many people (on the zbc forums) displacement in maya is a question, and has a running thread where there are always questions. I'd been asked by the moderators to post a quick tutorial, so there it is.
You'd be surprised - I was - at how fast this method is. I don't know how mental ray operates in stand alone, or through xsi, but in maya, this has been the quickest way I've found.
It goes against accepted knowledge about using approximation editors, but from my stand point this method works faster, and relatively effectively.
Give it a shot. There's a downloadable file and a texture.
regards,
-sunit
Offcourse its fast because it uses thse relatively low maya displacement approximation settings, the approx editor can do this too. Only most people realy dont understand anything about the approximation editor settings so they allwasy crank them too high.
And yes i know there are a lot of people running on pirtated versions of maya who never ver have even opened a manual or ever had any tuteage, who couldnt do anything if it wasnt for people writing all kinds of tutorials that demosntrate facts you can find by reading the manuals in firstplace.
Im not saying its wrong but the motives are a bit hazy.
Right....As far I can tell, you can't get these results using an approximation editor. With this speed, that is. Feel free to prove me wrong. It's not the most accurate application of the displacement, but it works, and for those of us looking for good ways to utilize zbrush with maya, this is a good alternative.
I don't know who you're talking about when you talk about never having opened a manual. The point of tutorials is to make easily accessible those facts that you can read. I was surprised when I discovered that this method worked faster, so I wrote a tutorial.
you can always give it a try. I've worked for many years in film doing this kind of stuff. It's not as if I come from an unskilled background.
cheers,
sunit
I cant acces the file (im not realy keen on registering to all the possible forums on the net) but i can easily recreate a similliar situation....
i can get many settings that are 10-15 secs faster...
But yes the default maya one is the same approximation as
spatial
fine
viewdependent
length 1.
sharp 0.833333
minsub 0
maxsub 5
Wich is pretty optimal, alias guys arent stupid theyve chosen THE best method, with generaly acceptable settings.
as atestament to the smartness of this setting i usualy set my override to, any other tesselation methods besides spatial fine are stupid to use.
spatial
fine
viewdependent
length 0.5-2
sharp 0-0.85
minsub 0
maxsub 5-6
read maya manual under http://localhost:4446/Maya6.0/en\_US/RefGui....html#SECTION85 for:
Fine Approximations3.1
Standard approximations as described in the previous section work under the assumption that as few triangles as possible should be used to approximate a surface to achieve a user-defined quality. mental ray 3.1 also supports a new approximation mode called fine approximation, which addresses the problem from a different angle: it is capable of efficiently expending very large numbers of triangles to faithfully approximate even very complex surfaces, especially displaced surfaces, without excessive memory consumption.
This is done by reducing the granularity of mental ray's cache manager. In mental ray 3.0, it operated on entire objects, which could become very large when tessellated. mental ray 3.1 applies cache management to smaller units formed by splitting objects into smaller sets, which can be individually tessellated without excessive memory requirements. This is especially useful for extremely detailed displacement maps.
ine general on optimizing renders or other mentalray issues refeer to:
http://localhost:4446/Maya6.0/en\_US/RefGuide/index.html
Wich is HIDDEN pretty well in the maya manual
Well because it acts like your smooth inside maya.
you could probably replace your smooth witha aparametrig subdiv approx with a small speed penalty, if you wished to avoid clutter.
Aslo you could accelerate a few seconds by uisng pure tris. and use less memory.
read: http://localhost:4446/Maya6.0/en_US/index.htmlhttp://localhost:4446/Maya6.0/en\_US/index.html
one can easily shave of most mentalray renders by playing a few accel tricks without loosing much or no quality. Usualy the acceleration you acchieve form a well set up render by 10-50% of the original time. Offcourse using wrong settings can give you rendertimes of 10 times the standard. And tis does not only apply to the maya implementation.
So allmost any production would benefit form a renderwrangler, as a good onw can save you weeks or even months of rendering.
This thread has also been going at cgtalk:
It sounds like there's no way to use the two in conjunction - not having the standalone, i don't know if editing the .mi file will work better. as far as i can see the (checking in the .mi) there's no way to utilize the displacement, without maya adding a line separate from the subd approx...
cheers,
-sunit
oh yeah sorry about tha, okay here goes:
As far as ive tested and read in the manual MR chooses one of them, so if the surface is displaced then it chooses the displacement, if not then it chooses surface. As such there may be 2 of theese declarations as mr chooses the displacement if the surface displaces and ignores it if not, therebuy choosing the surfface approx.
Also you can define seperate displacements for raytraced beams as opposed to view beams if you wish (can be usefull optimization).
it seems as though, with maya-mr, once you've got a subdiv. approx. attached to your mesh or converted your mesh to a subdiv., then no matter whether displacement exists or not, mr will render with the subdiv. approx. settings. the moment i have a subdiv. approx. attached to my object, my displacement approx. ceases to have any effect. i would love to be able to use mr subdivisions and also take advantage of the displacement approximations, but this doesn't seem possible.
cheers,
sunit
Topic | Category | Replies | Views | Activity |
Who is interested in deploying this real-time renderer? | Maya | 0 | 857 | Mar 3 |
Free Toolkit for Modeling, Rigging, Animation! | Maya | 0 | 136 | 14d |
Project a geometry onto another geometry with a locator origin | Maya | 0 | 63 | 3d |
