Oct 2013
2 / 3
Oct 2013
Oct 2013
I need to find a fast, automatic method for combining 2 polygon surfaces. The idea would be similar to a Boolean, but on more of a 2D scale. Please take a look at the image "quad-transition1.jpg". The highlighted ring is a quad strip drawn with the new modeling toolkit. I want to combine this with the surrounding surface, so that the end result looks like the image "quad-transition2.jpg". The surrounding surfaces is split, overlapping faces are removed, and all vertices on the new resulting surfaces line up with one another. No faces overlap. I created this example by hand, which takes far too long.
  • created
    Oct '13
  • last reply
    Oct '13
  • 2
  • 1.9k
  • 1
    user
You can actually do the cutting with booleans and the drop on surface is pretty easy to do. Its just that i wouldnt use a tool like this because it creates normals that are really useless.
